1 members (SandraD), 56 guests, and 5 robots.
Topics128,021
Posts1,055,355
Members48,420
#92636 08/12/2005 10:30 PM
I picked up a remote starter (2 alligator clips and wired push button) for 6 and 12 volt use, but I can't get it to crank over the starter. No directions with it, so I hooked up one lead to the positive on the starter and the other to ground - push the button and nothing. What am I missing or mis-connecting? Would make it easire to set points / check engine, etc. BW
#92637 08/12/2005 10:38 PM
foot stomp starter? the positive on the starter is before the switch so you have to push the switch to get the juice to the starter - your remote switch is for an key start setup
get a honkin big screwdriver [or pry bar] and get it between the switch and the firewall, watch distributer, push down on bar - easy, just make sure it's in neutral! grin
#92638 08/12/2005 10:41 PM
Riding in the Passing Lane
You should connect one lead to the small wire on the selenoid marked S.It usually is a purple wire. The other is hooked to the pos. cable or any good hot wire. This is for GM. Other makes are different. You probably have fried that remote starter switch though.
1972 Chevy c10 Cheyenne Super
#92639 08/12/2005 11:05 PM
Wrench - your talking about the key switched starter, I think he's got a foot stomp 51, no solenoid - but yer prolly right about fryin the remote switch!
