8 members (KEVINSKI, mick53, 55shaker, Peggy M, Gdads51, Hanks custodian, MickeyP, 1 invisible),
148
Mod | | | Forums66 Topics128,089 Posts1,056,137 Members48,435 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I'm sure it's just me, but none of Tim's links ever work for me.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Mar 2011 Posts: 1,146 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 1,146 | Hello, Here is a photo album of a 1955 Chevy 1st series 1/2 ton truck with a Hydra-Matic https://picasaweb.google.com/106723428487424188160/1955ChevyTruckBlue?noredirect=1The Hydra-Matic in this truck has a Cadillac center case which means it is pan fed. Pan fed means there is a tube attached to the tranny oil pan to check and fill tranny from engine compartment. There is no side smoke stack filler on a Cadillac case. All internal parts are the same. Just the case is different. The rear tranny cross member is there but not used for tranny support. As you can see it has open drive shaft. Thanks | | | | | Joined: Mar 2011 Posts: 1,146 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 1,146 | Hello, Took me awhile but I found the 1954 Chevrolet 1/2 ton truck with 4 speed tranny . No tranny rear support cross member. Enclosed drive shaft. Picture Album Bonus: Old UPS 1954 Chevrolet 1 ton Panel truck with 4 speed tranny. 2 piece Open drive shaft with center intermediate bearing. pic 1 pic 2Thanks | | | | | Joined: May 2006 Posts: 63 'Bolter | | 'Bolter Joined: May 2006 Posts: 63 | So, I went & wire brushed the rear end & found this stamped on it. N K1224 Not sure if the "N" is part of it since its spaced kind like the way I typed it on here.
So what I'm trying to find out is what the gear ratio of this rear is. I got it off of a 54 GMC Hydra-matic open drive.
Any info appreciated Thanks Javier | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Did that code come off a plate attached to the transmission?
If it did, what is the color of the plate?
| | | | | Joined: Mar 2011 Posts: 1,146 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 1,146 | So, I went & wire brushed the rear end & found this stamped on it. N K1224 Not sure if the "N" is part of it since its spaced kind like the way I typed it on here.So what I'm trying to find out is what the gear ratio of this rear is.I got it off of a 54 GMC Hydra-matic open drive. Any info appreciated Thanks Javier What tonnage/series is the truck. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | The color of the ID plate would ID the size (if it is a 1954 H-M transmission): At this link are GMC tag colors for different sizes of 1954 Hydra-Matic transmission. Chevrolet 1954 H-M tag colors are the same as GMC tag colors on 1/2 (3100 or 100 series), 3/4 (3600 or 150 series), and 1 ton (3800 or 250 series) transmissions. If it has an open driveshaft, and if it is a 1954 GMC Hydra-Matic transmission, it would have to be from a 3/4 ton or larger truck. | | | | | Joined: May 2006 Posts: 63 'Bolter | | 'Bolter Joined: May 2006 Posts: 63 | I appreciate all the help, but unfortunately all I have is the rear end from this 54 GMC Hydra-Matic truck. No trans or color tags to work with just the rear axle. Ive had it sitting in my back yard for some years. What Im trying to figure out is if this rear end will allow my truck to drive at 60MPH-70MPH?
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | If GMC rear-end codes are the same as Chevrolet codes: NK 1224 NK = 1955 1/2 ton rear-end from the Detroit assembly plant 12 = December 24 = 24th If that is correct, it would be a 3.90:1 rear end (open drive-shaft). | | |
