1 members (CuzzFuzz), 228 guests, and 6 robots.
Topics128,101
Posts1,056,181
Members48,436
#926005 03/09/2013 11:21 AM
b10
Offline
On my last slide under to start removing the shifter plate on Betsy i noticed that the trans had only two bolts one on the top in front of the shifter plate and one on the other side on the bottom. the other two holes had what looked like guide pins. IS THIS NORMAL? I have never worked on any thing that had guide pins like that all the auto trans had bolts in all holes. I do not know if it came out of the factory like that or is this another SHOEMAKER JOB. Feed back please and thanks again.
On my '48 there's a bolt on the inner side of the bellhousing.
1948 Chevy 1/2-Ton
"Tuesdays with Morris"
In the Legacy Gallery
Find it - Fix it - Drive it
what year? what engine and trans?
some have bolts from both sides of the bellhousing, the inside ones are accessed by removing the bottom dust shield
b10
Offline
1951 three speed enclosed driveshaft. now a 235 was a 216.
helps to have the shop manual handy
b10
Offline
And now i feel like a dammm fool should just kept going like i always do.
