7 members (NJC, Gray_Ghost, GMCJammer51, Greg_H, 50Chevy3100, 1955 1 Series, 1 invisible), 74 guests, and 1 robot.
Topics128,073
Posts1,055,908
Members48,429
#925607 03/07/2013 7:32 PM
I am going to run a 88 pontiac 350engine and 700r4 trans.It was tpi computer controled system but am changing to carb.I need to do something withe the trans .I will be running new Dolfin gauges with elecronic speedomiter[58 CHEVY TRUCK]and have to run a speedo system without changing the tail shaft or run a mechanical speedo Can someone tell me what would i need to do for speedo system .Thank you
chevyman1 #925982 03/09/2013 9:12 AM
you need a pulse generator/transducer/sender, see here, bottom of page
chevyman1 #925998 03/09/2013 10:22 AM
chevyman1 #926605 03/11/2013 4:30 PM
Thank you red 58 and mnsmith.Ihope i made it clear that im no longer using a computer on this project. I am putting this engine and transmission in a 58 chevy truck. Iam buying new gauges and was not sure how to run a speedo.The puls generator seems like the way to go.Does the genarator send a signal to the Dolphin speedo. Thank you
chevyman1 #926620 03/11/2013 5:36 PM
yes, that's what the pulse generator is for - it comes from Dolphin, so I'd expect it to work with their speedo, but you might inquire about compatibility with the particular trans .... and yes, I understand the computer thing, I have to deal with that on my bus, using a 2000 4L80E and will have to go with an electronic speedo frown
chevyman1 #926988 03/12/2013 7:55 PM
How does the pulse genarater connect to my 88 700 r 4 transmissionis there a post explaining how that would need to be connected to the tranny and how to connect to the dolphin gauges.Tony
chevyman1 #927000 03/12/2013 8:42 PM
it's a 'black box' that converts the mechanical spin to the electrical signal the speedo needs, not positive for your application, but likely it would install where the speedo cable connects and the spin would generate an electrical signal on a wire to the speedo - might mount under the dash with the speedo cable connected to it, then wires to the speedo - easy to ask Dolphin about your particular setup
