3 members (JW51, baldeagle, moparguy), 85 guests, and 4 robots.
Topics128,014
Posts1,055,327
Members48,419
#92581 08/08/2005 12:47 AM
Several years ago I had a electrical fire under the hood of my '66 C-30. The insulation on auxiliary wire that runs from the postive battery terminal to the horn relay was damaged where it runs through the grille. This resulted in a electrical fire under the hood. Fortunately, I had a fire extinquisher in the cab, and was able to put it out. When I replaced the burned wires, alternator and voltage regulator, I put a fuse link near the horn relay to minimize any damage if something like this happened again.
It might be a good idea for anyone with one of these trucks to install a fuse link. It could save your truck from being destroyed by a fire.
#92582 08/08/2005 7:48 PM
Quote
Originally posted by caroline's truck:
how about using some good modern cable split tube as an insulating housing. comes in black and white at most good electrical supply houses/ parts stores. IT's cheap insurance and shows a quality job done well.
Gooday
Jim
small wheel moves by fire and rod,
big wheel fires by the grace of god,
everytime that wheel turns round,
bound to cover just a little more ground.
#92583 08/08/2005 8:09 PM
Doug is right, GM never put any protection on those hot wires 60-66, also the ammeter wires are unfused if the truck has guages. I put a 2 amp fuse in those connections. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
