1 members (baldeagle), 56 guests, and 9 robots.
Topics128,020
Posts1,055,345
Members48,419
#925592 03/07/2013 6:58 PM
I have a borgwarner od from i'm told a 55 chevy car. Want to test the solenoid and i now i read on here somewhere how to do it but can't seem to find it. Can someone tell me how to check this thing. It's not on the tranny now.
basham #925606 03/07/2013 7:30 PM
To test it, you need to supply power to terminal #4 on the solenoid housing. It should be marked with a "4" next to it. The other terminal is #6, which is the pull in/hold in windings for the kickdown function. It can be tested the same way. It is grounded through the case.
Here's a link to the overhaul manual . It's a generic manual, convering only the overdrive parts, but they are essentially the same regardless of what the main transmission is.
Bill Burmeister
basham #925608 03/07/2013 7:41 PM
If its like mine there should be 2 bolt connections.
The larger one is to energize the solenoid. The other is to ground the ignition when the passing gear button is pushed.
If you hook jumper cables to the case and the large bolt it should pull the shaft inward to the solenoid.
The small one should be grounded when the solenoid is energized.
basham #925622 03/07/2013 8:58 PM
All kinds of info on that transmission on Deve's Antique Trucks
Cletis #925838 03/08/2013 5:23 PM
well, i retested it and it works. must not have had a good ground. thanks.
