| | | Forums66 Topics128,022 Posts1,055,373 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2011 Posts: 22 New Guy | | New Guy Joined: Nov 2011 Posts: 22 | I am going to run a 88 pontiac 350engine and 700r4 trans.It was tpi computer controled system but am changing to carb.I need to do something withe the trans .I will be running new Dolfin gauges with elecronic speedomiter[58 CHEVY TRUCK]and have to run a speedo system without changing the tail shaft or run a mechanical speedo Can someone tell me what would i need to do for speedo system .Thank you | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | you need a pulse generator/transducer/sender, see here, bottom of page Bill | | | | | Joined: Oct 2005 Posts: 4,249 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,249 | | | | | | Joined: Nov 2011 Posts: 22 New Guy | | New Guy Joined: Nov 2011 Posts: 22 | Thank you red 58 and mnsmith.Ihope i made it clear that im no longer using a computer on this project. I am putting this engine and transmission in a 58 chevy truck. Iam buying new gauges and was not sure how to run a speedo.The puls generator seems like the way to go.Does the genarator send a signal to the Dolphin speedo. Thank you | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yes, that's what the pulse generator is for - it comes from Dolphin, so I'd expect it to work with their speedo, but you might inquire about compatibility with the particular trans .... and yes, I understand the computer thing, I have to deal with that on my bus, using a 2000 4L80E and will have to go with an electronic speedo  Bill | | | | | Joined: Nov 2011 Posts: 22 New Guy | | New Guy Joined: Nov 2011 Posts: 22 | How does the pulse genarater connect to my 88 700 r 4 transmissionis there a post explaining how that would need to be connected to the tranny and how to connect to the dolphin gauges.Tony | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | it's a 'black box' that converts the mechanical spin to the electrical signal the speedo needs, not positive for your application, but likely it would install where the speedo cable connects and the spin would generate an electrical signal on a wire to the speedo - might mount under the dash with the speedo cable connected to it, then wires to the speedo - easy to ask Dolphin about your particular setup Bill | | |
