0 members (),
46
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#92542 08/06/2005 1:49 AM | Joined: Apr 2005 Posts: 345 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 345 | '54 GMC 150 Anyone ever pull the knob/shaft out of the headlight switch and when you went to put it back in it wouldn't engage?
Please advise. Thanks | | |
#92543 08/06/2005 2:31 AM | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | I did on mine 52 chevy ending up in my hand, I did get it back in place, some sort of clipp , I think holds it in,, happend again and I could not get it back in, order a replacement , cheap deal but it works, it turns on rather pull out...... Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | |
#92544 08/06/2005 2:28 PM | Joined: Jul 2005 Posts: 27 Junior Member | | Junior Member Joined: Jul 2005 Posts: 27 | My 66 did that ,I took it apart to fix it and it kinda exploded. get a replacement :confused: Jeff.
I'm older than my truck but it's smarter than me! 66 GMC 3/4 ton fleetside 283, turbo 400.
#92545 08/08/2005 5:16 AM | Joined: Apr 2005 Posts: 345 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 345 | Thanks for the good news. I'll order a new one. | | |
#92546 08/08/2005 6:26 AM | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | Don't get a new one. Get a good used original, they work just fine on 12v (if you've converted), and are much better built than the new pieces of imported trash. | | |
#92547 08/08/2005 6:57 AM | Joined: Apr 2005 Posts: 345 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 345 | OK panel, Any advice on where I'd find a good used one? | | |
#92548 08/08/2005 3:31 PM | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | There's one on Ebay right now. | | |
#92549 08/08/2005 4:27 PM | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | There is a button on the side of the switch and if you depress it the knob will slide right in. Reach up under and press it with your thumb. It's on the left side of the switch in about the middle and it's about the size of a pencil eraser.Here's a pic. Good luck. http://chevy.tocmp.com/1949_53shop/12electrical/12_46.HTM Curt
1952 1300 Canadian 1/2 ton restomod You Tube | | |
#92550 08/09/2005 9:34 AM | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | tlorber, Mother Trucker, Bowtie Bits, or any other place that has used parts should have boxes of good headlight switches. Check the links page and eBay. One shouldn't cost too much, they rarely go bad. | | |
#92551 08/11/2005 9:25 PM | Joined: Apr 2005 Posts: 345 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 345 | | | |
