Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
3 members (WICruiser, kades51, fonz8261), 47 guests, and 1 robot.
Topics128,009
Posts1,055,293
Members48,419
#92542 08/06/2005 1:49 AM
'54 GMC 150
Anyone ever pull the knob/shaft out of the headlight switch and when you went to put it back in it wouldn't engage?
Please advise.
#92543 08/06/2005 2:31 AM
I did on mine 52 chevy ending up in my hand, I did get it back in place, some sort of clipp , I think holds it in,, happend again and I could not get it back in, order a replacement , cheap deal but it works, it turns on rather pull out......
Redryder pix
My Hotrod
#92544 08/06/2005 2:28 PM
Junior Member
Junior Member
My 66 did that ,I took it apart to fix it and it kinda exploded. get a replacement :confused: Jeff.
I'm older than my truck but it's smarter than me! 66 GMC 3/4 ton fleetside 283, turbo 400.
#92545 08/08/2005 5:16 AM
Thanks for the good news. I'll order a new one.
#92546 08/08/2005 6:26 AM
Don't get a new one. Get a good used original, they work just fine on 12v (if you've converted), and are much better built than the new pieces of imported trash.
1954 GMC De Luxe COE
#92547 08/08/2005 6:57 AM
OK panel,
Any advice on where I'd find a good used one?
#92548 08/08/2005 3:31 PM
There's one on Ebay right now.
#92549 08/08/2005 4:27 PM
There is a button on the side of the switch and if you depress it the knob will slide right in. Reach up under and press it with your thumb. It's on the left side of the switch in about the middle and it's about the size of a pencil eraser.Here's a pic. Good luck.
http://chevy.tocmp.com/1949_53shop/12electrical/12_46.HTM
Curt
You Tube
#92550 08/09/2005 9:34 AM
tlorber, Mother Trucker, Bowtie Bits, or any other place that has used parts should have boxes of good headlight switches. Check the links page and eBay. One shouldn't cost too much, they rarely go bad.
#92551 08/11/2005 9:25 PM
Thanks for the input.
