1 members (Otto Skorzeny),
81
Mod | | | Forums66 Topics128,034 Posts1,055,547 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2010 Posts: 41 New Guy | | New Guy Joined: Dec 2010 Posts: 41 | does anyone have any ideas or where to purchase door pulls for my 65,i was thinking of something that would use the exsisting screws on top of access panel on door,other people tend to pull on the end of the handle when closing door and it is getting sloppy,any ideas or comments would be appreciated,i was thinking of making my own from leather,but if someone make a product to fit would be nice,thanks gents, | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the armrests work real good for door closing
Bill | | | | | Joined: Dec 2010 Posts: 41 New Guy | | New Guy Joined: Dec 2010 Posts: 41 | Ive have 2 65s,neither has armrests,was this an option?there are no holes either where an armrest would have previously exsisted | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | pick your color - if they didn't come with arm rests from the factory, there were no holes in the cover plate, but the threaded inserts will be in the door behind it Bill | | | | | Joined: Dec 2010 Posts: 41 New Guy | | New Guy Joined: Dec 2010 Posts: 41 | well I learned something today,thanks | | | | | Joined: Nov 2008 Posts: 293 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 293 | On our 66 Suburban, it had it on the drivers door, but not the passenger door. I am adding them to the Passenger side, and there were no weld nuts behind the cover. You can buy the weld nuts from an aftermarket parts supplier. I believe I got mine from Orange truck and car shop in CA. You will need to transfer the hole thru the side cover. I think there are dimensions in the service manual. You can probably get a decent arm rest from one of the parts sellers here in the parts for sale forum. | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | There are no threaded inserts in the door shell, behind the door panel, but there are two sets of square holes, in the door shell. A pair for the forward position and a pair for the rear position. Either position, requires a pair of spring nuts, which are square nuts with a capture spring on two edges, that hold them in the square hole, from the backside of the door shell. You can get them from the yellow bins of most of the large box stores, like Lowe's & The Home Depot.
| | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | the ones that are in some of the ones I had were pinched into the holes from factory; no weld or no springs ron | | | | | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | Shaker, Any of the parts houses as OEM replacements you. The come with a backing plate as well. However, I will also chose to place a larger plate in the panel as well to spread out the load, 1/8" piece of flat aluminum, no real weight added. Other than a straight nut and bolt application to secure, you can choose you use caged nuts.
I have the factory accessory installation manual and can scan you the page if you need it, just pm me and put in a message so I don’t think its junk mail.
| | | | | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | | | | | | Joined: Dec 2010 Posts: 41 New Guy | | New Guy Joined: Dec 2010 Posts: 41 | once again thanks to you gents for all the info,im going to pull panel off and have a look,thanks guys, | | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | Classic Parts sells them too.. and if you type in "stovebolt" you get 10% off there already better pricing. http://www.classicparts.com/searchprods.aspI bought some a while back but haven't installed them yet, very helpfull thread, thanks to all. John | | | | | Joined: Sep 2011 Posts: 131 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 131 | Hi Shaker from Gleichen Ab.
I too purchaced the new aftermarket arm rest/ door pull from Classic industries. Up here try Scotts Super Trucks in Penhold.
Or get back to me as I am headed to Ca.for 10 days next month and could bring two back duty free.
Howie, 55 one ton, 62 C-10. 403-734-3449
1 1955 Chev one ton. 261 engine
3 1962 Chev c-10 261 engine 4 1966 Plymouth VIP 5.7 GenIII Hemi 5 1966 Imperial Crown Coupe 440 engine | | | | | Joined: Mar 2010 Posts: 207 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 207 | JohnTSmith,
You sure have some nice trucks there!
Tom 1965 Chevy C10, 230 straight six, 2WD, 4-speed manual
| | | | | Joined: Dec 2010 Posts: 41 New Guy | | New Guy Joined: Dec 2010 Posts: 41 | hello gleichen,we are almost neighbors,thanks for the offer,ill try scotts and see what they have,ill let you know ,thanks | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | If the arm rests are attached to the inner door panel, they will work, but you may get some "oil-canning" in the inner door panel, over time. The arm rest was secured, through the inner door panel, into the door shell structure with a special nut, as described above. Obviously, there are countless ways to secure them...owner's choice. | | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | the nuts are 1/4 nc. just grind a centre point on one end and insert it with the point towards where the panel will be. fasten the panel in several points and give a little tap with your hand on the panel where the point is. take the panel off and drill it ron | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | From the rear of the door, use the 1st & 3rd square holes for the rear arm-rest position or the 2nd & 4th square holes for the forward arm-rest position.
Although I don't have the image uploaded on my computer, the Accessory Installation manual has a template for locating the holes in the inner door panel, for drilling. Ron's suggestion above, is a great solution, if the template isn't available.
| | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | Thanks for the tips gentlemen.  | | |
