4 members (Shaffer's1950, cmayna, 2 invisible),
122
Mod | | | Forums66 Topics128,079 Posts1,056,286 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2012 Posts: 112 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2012 Posts: 112 | 1st gear rattles or chatters yet reverse does not also 2-3 gears are quiet.Anybody got any ideas about the shaft being bad. If i had clutch -pressure plate- T-Out bearing problems it would do it all the time?I have access to a replacement trans so i may just change it. I know it is best to get in there and look at the guts but it may be easier to just swap to the new old one. This is only 1st when you start out from a stop sign. THANKS | | | | | Joined: Feb 2011 Posts: 34 New Guy | | New Guy Joined: Feb 2011 Posts: 34 | Yes, the first gear and reverse gear is the same, it is controlled by a first and reverse idler.If it was the main shaft (unlikely) you would not go nowhere. Pop open the inspection plate and see if the gear is worn or has excessive play, or teeth at the bottom. Let us know what you find. | | | | | Joined: Sep 2012 Posts: 112 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2012 Posts: 112 | Time to jack her up and crawl under this weekend. Thank you again. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Even though first and reverse share one of the gears, called the first reverse slider, they use the opposite sides of the gear. It is common for the first gear side of that gear to wear through the case hardening much faster then the reverse side as it does not see as much use.
See the USA in your vintage Chevrolet! My Blog | | |
