8 members (JoeDude, dt235sd, Peggy M, Hotrod Lincoln, Perro, 48jim1ton, Shaffer's1950, 1 invisible),
72
Mod | | | Forums66 Topics128,032 Posts1,055,516 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2013 Posts: 14 New Guy | | New Guy Joined: Mar 2013 Posts: 14 | New to the site and rebuild and may be a ridiculous question. Without tearing into engine, how do you know if you have a 235 or 216? Rebuilding a 53 Chevy truck. I'd be surprised if it is a 235 but I'm beginning to think it might be. | | | | | Joined: Oct 2011 Posts: 206 Shop Shark | | Shop Shark Joined: Oct 2011 Posts: 206 | well if its a later 235, the valve cover is held on by four bolts around the perimeter,
216s and early 235s had 2 bolts in the center of the valve cover keeping it on. | | | | | Joined: Mar 2013 Posts: 14 New Guy | | New Guy Joined: Mar 2013 Posts: 14 | Thanks for your help. That really confirmed my thinking that the valve cover was different. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | The best ways to find out what engine you have is to post the Engine Serial number that is pressed into the block just to rear of where the distributor enters the block. Sometime that code is not enough information and you need to find the casting codes. If you have a four-screw valve cover, here are locations of casting codes. | | | | | Joined: Nov 2000 Posts: 1,966 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,966 |
Professional Novice
