3 members (Nick in Manitou, Wally / Montana, 1 invisible), 58 guests, and 3 robots.
Topics128,076
Posts1,055,920
Members48,429
#924358 03/03/2013 7:32 AM
removed old mc from my 48 gmc, putting in a dual bowl, do you really need to bench bleed it, the lines already have fluid in them and when you fill the mc up, doesn't seem like much air to bleed...
Riding in the Passing Lane
Yes, its best to bench bleed the master cyl. Especialy dual type. Mount it in a vise & put a little fluid in it. Hold your fingers ovrer the holes like chheck valves. & pump the master cyl. with short strokes. When you get fluid to both out lets you are good to go.
1972 Chevy c10 Cheyenne Super
i guess it won't take that long, thanks for info wrenchbender
Here is the way I do it. When you get a new or rebuilt MC usually they will include a bleeder kit made of plastic fittings and short peices of plastic tube. They screw into the MC and run the lines back into the bowls, fill with fluid and pump slowly until all bubbles are gone. that way you are sure the MC is full. I have a few hard line made up to do the same thing. Saves a lot of time and brake fluid.
IF YOUR NOT LIVING ON THE EDGE YOU ARE TAKING UP TOO MUCH SPACE
57 CHEVY SWB STEP SIDE
http://s1099.photobucket.com/albums/g388/vetteman199/
