| | | Forums66 Topics128,080 Posts1,055,945 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2010 Posts: 182 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 182 | The Electrolock on the '42 1/2 ton I'm working on has been cut by a previous owner and the wiring in it is bad anyway so I'm looking for a way to be able to turn the ignition off and on without it. I still have the foot starter but I'm converting the truck to 12 volts. I'm thinking about just using a universal key lock dash switch like this: http://www.parts123.com/parts123/yb.dll?parta~dyndetail~Z5Z5Z50000014a~Z5Z5Z54057~P19.50~~~~S3Q904OP2N75272245858f~Z5Z5Z5~Z5Z5Z50000014x and just wiring it the way the '47-54 trucks were wired since they didn't have Electrolocks but still had the foot starters. I still want to be able to turn the ignition on and off with an original looking key.
Is this the best way to go, or is there a better way to do this? Also, is there one of the key lock cylinders like the above that can be bought at a local parts store (like Carquest or O'reillys) that fits in the hole in the 41-46 dash and has the correct looking key?
Thanks for any help. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I see used electrolocks on ebay all the time. Many are pretty cheap. They aren't difficult to rebuild. The Filling Station has a step-by-step rebuild guide for the '37-'39 electrolock that will also work for other years. It shows how to disassemble the switch to reattach/replace the wire. If you want to just get rid of it you can still use the original switch and simply run a wire from the switch to the top of the coil.
| | | | | Joined: Aug 2010 Posts: 182 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 182 | Thanks for the tip on the Filling Station manual. I may order it even though this electrolock is way beyond repair. I see the ones on eBay, too, but all are for different vehicles. I thought about gutting the thing and just running a wire to the coil as you suggested, but then I figured all I would have is basically just a 71 year old lock cylinder for all my trouble. I can't use the coil end of the electrolock anyway (if it was still there) since I'm using a 12 volt coil. That's when I decided I might as well just use one of the new universal type lock cylinders with the original style key (if it fits the hole in the dash). I could even run the wire to the coil in metal conduit, and to the average person it would look original.
I guess I mainly wanted a part number of a lock cylinder like the one I linked to from Filling Station that I could buy at a local part store so I don't have to go to the trouble and expense of ordering it. It's always nice (and a lot easier) just to be able to give the parts store people a part number rather than making them go thru their books.
Maybe I need to re-post the request for the part number as just that. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | you don't need a part number for any ignition switch you could get at a FLAPS, just ask for a "forklift ignition switch", otherwise anything useful would be too old [obsolete] to be found locally
Bill | | | | | Joined: Aug 2010 Posts: 182 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 182 | How many terminals do you need and what do the terminals need to be for? | | |
