| | | Forums66 Topics128,193 Posts1,057,367 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2010 Posts: 97 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 97 | Two horn questions: 1. Would the original horn on this truck have been an "a-hoo-gah" horn?
2. About how many amps would a 12v a-hoo-gah horn pull (the horn I have I estimate is about 25 years old).
Thanks, Mike | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the type of horn you're thinking [ like this, "Klaxon"] was aftermarket and primarly found on 20's & 30's Fords, 6 volt - no doubt there are Klaxon repros around in 12V, but current draw would be unique to the particular item you have .... always a good idea to use a relay for a horn regardless Bill | | | | | Joined: May 2001 Posts: 477 Shop Shark | | Shop Shark Joined: May 2001 Posts: 477 | 1. no. solid tone horn. 2. amp draw about 7-10 i think. most horns used a relay. i suggest you do the same.
consider using what you have as a backup. horns back when were not made for high speed vehicles. | | | | | Joined: Nov 2010 Posts: 97 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 97 | Thanks Bill and Koolkar. I will definitely get a relay in the near future (I keep blowing the horn fuse). As for horn sound, I'm probably considered a purist on most things regarding my truck, preferring everything to be stock or to look as much like stock as reasonably possible. But people really get a kick out of my ah-hoo-gah horn so I will keep it even though its not the original sound. | | | | | Joined: Aug 2005 Posts: 6,378 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,378 | Your '37 should have had a single horn mounted to the manifold. Single horns didn't usually have a relay. The accessory dual horns did use a relay. I don't remember what size fuse I have for my dual horns, I can go look if you want that info.
| | | | | Joined: Nov 2010 Posts: 97 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 97 | Thanks Tiny. No need to look for fuse size, I'll just use the size recommended for the relay. Mike | | |
