7 members (Maybellene, Hotrod Lincoln, MNSmith, 55shaker, 51sub, Jon G, 1 invisible),
103
Mod | | | Forums66 Topics128,042 Posts1,055,595 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#92394 07/22/2005 3:28 PM | Joined: Feb 2005 Posts: 19 Junior Member | | Junior Member Joined: Feb 2005 Posts: 19 | What has to be done to modify my 235 6cyl generator bracket to make it possible to use a gm alternator. Any help would be deeply appreciated. John | | |
#92395 07/22/2005 3:49 PM | Joined: Dec 2003 Posts: 265 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 265 | Take a look at the brackets from www.americanclassic.com or www.chevyduty.com That should give you a pretty good idea of the design you need. | | |
#92396 07/22/2005 7:28 PM | Joined: Oct 2003 Posts: 297 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2003 Posts: 297 | jw4413-lot of info if you use the search mode. i personally used my old bracket. (54 235) took it off and measured how far forward it needed to be placed to line up with crank shaft pulley. redrilled holes in the bracket to match the old ones in the block. i then used an "all thread" bolt to mount the alternator to the new backet. the all thread gives you another way of adjustment to line up your belt. i also took the old generator bracket (adjustment bracket) - hammered it flat - turned it upside down and used it again for the top bracket. poor boy solution but works fine and doesn't look bad either.
54 3100 w/62 235 "Yosemite Sam" Born a Jay Hawk, raised an Okie and resurrected in Texas!http://community.webshots.com/user/djed50
#92397 07/23/2005 6:29 AM | Joined: May 2003 Posts: 13 Junior Member | | Junior Member Joined: May 2003 Posts: 13 | I'll second djed50. Did about the same, only I didn't flatten the adjustment bracket just turned it upside down. | | |
#92398 07/26/2005 10:14 PM | Joined: Apr 2005 Posts: 345 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 345 | jw, I converted my 235 to a Delco alternator. I took a lower alternator bracket from a '67 6 cylinder chevy truck since the delco was OEM on that vehicle (the 8 cylinder won't work-totally different setup). I had to egg out one of the holes slightly (I think it was the front hole) and the alternator fit right in. For the top bracket I used my old generator bracket- which may not have been original, and had to bend it a bit. The top ones are easier since there are so many different configurations out there. | | |
#92399 07/26/2005 10:20 PM | Joined: Apr 2005 Posts: 345 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 345 | jw, I converted my 235 to a Delco alternator. I took a lower alternator bracket from a '67 6 cylinder chevy truck since the delco was OEM on that vehicle (the 8 cylinder won't work-totally different setup). I had to egg out one of the holes slightly (I think it was the front hole) and the alternator fit right in. For the top bracket I used my old generator bracket- which may not have been original, and had to bend it a bit. The top ones are easier since there are so many different configurations out there. | | |
