7 members (dt235sd, 3B, frogfarmer, 1955 1 Series, Bruce 1954-4100, DennisM, 1 invisible),
88
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,074 Posts1,055,910 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#92376 07/19/2005 3:20 PM | Joined: Mar 2005 Posts: 16 Junior Member | | Junior Member Joined: Mar 2005 Posts: 16 | OK guys, here's one from a newbee....I have a 56 Chev 3800 w/ 57 283ci. I'm loosing over 1/2 volt in battery overnight, with the key off. I'm an electrical idiot, so replaced battery, cables, regulator, ignition resistor, cleaned neg ground contact at firewall, and checked circuits by removing fuses, but still get a .4 volt draw when measuring between pos cable and battery. My auto shop said they could not find anything wrong with the alternator. Anybody have a solution to my problem, No, I don't want to sell the truck, I can beat this demon!! Winning suggestion wins a free trip to Sedro Wooly (just kidding). Thanks for any help...Frank | | |
#92377 07/19/2005 3:41 PM | Joined: Apr 2000 Posts: 499 'Bolter | | 'Bolter Joined: Apr 2000 Posts: 499 | Alternators can and often do have internal shorts and still capable of charging the bat at 14volts. The typical alt tester won't indicate a problem. Using the same setup you used when pulling fuses, take the wires off the alt.
'67 GMC 3/4 292 4spd
#92378 07/19/2005 4:09 PM | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | Had one on my 52,, never did find it,,I got me a disconnect switch, just turn it off when I am thru with it for the night,,,,,,,,,mine has a 235, with 12 volt,,,,,good luck .....Fred Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | |
#92379 07/19/2005 4:39 PM | Joined: Mar 2005 Posts: 16 Junior Member | | Junior Member Joined: Mar 2005 Posts: 16 | you guys are fast...thanks for responding! I think the shut off switch is a good idea and was going to do that until I can find the real problem. Also, I'm not done exploring the possibility of the alternator. How do I check it? Remember, I'm an electrical idiot!! thanks, Frank | | |
#92380 07/19/2005 5:56 PM | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | I am not sure,my brother spent about 2 hours trying to find me and he is good at this stuff, he also suspected the alt. as last result,did something with one of the wires on it, then the truck would not die after turning off the switch, he checked my electrical wipers, radio, was surprised that he could not find it, I told him to stop as he already spent a lot of time on it,, to began with it I replace a cable that was in bad shape,ground I believe it was, thought this was the problem, then I checked the alt... it was bad, so I bought a new one, thought this was the cure,, took about 5 days and the batter was so bad that it would not take a charge,,not to bore you anymore, if you find out what it is, I may go back and look again,, this has been about 2 yrs ago..Fred Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | |
#92381 07/19/2005 11:33 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | A slight draw on the battery is normal if it does not run the battery down over a long period of time. There is slight drain from dust, moisture, or other foreign material in the switches & battery case. A battery will have lower voltage after setting awhile because the surface voltage drains off.  They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#92382 07/20/2005 1:58 AM | Joined: Apr 2000 Posts: 499 'Bolter | | 'Bolter Joined: Apr 2000 Posts: 499 | Let me try this again. Take the wires off the alt. If the bat stops draining down overnight, you can conclude there is a relationship.
#92383 07/20/2005 2:47 AM | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | I think the normal drain is less then 3MA..Fred Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | |
#92384 07/20/2005 3:15 PM | Joined: Mar 2005 Posts: 16 Junior Member | | Junior Member Joined: Mar 2005 Posts: 16 | thanks everyone....I will try the alternator AGAIN ! This has more than normal battery drain, over .6 volts overnight, and will be dead in a few days....NOT ACCEPTABLE!! ....it is broke, and I've got to fix it or I can't "just drive em"....... | | |
#92385 07/20/2005 8:06 PM | Joined: Jun 2005 Posts: 153 Member | | Member Joined: Jun 2005 Posts: 153 | frank, sounds like you're pretty capable, electrically speaking. If you find its not the alternator, and assuming you don't have a clock (or in internal one inside an aftermarket, modern type radio), alarm system or other obvious 'always hot' drain, check the cigarrette lighter and all light sockets and turn signal indicator for continuity that shouldn't be there (shorts) using a volt ohm meter (VOM). tony
Overland Blue, 1953 GMC 1/2T, 100-22, 228/1bbl, 4sp/4.10 6v, shortbed/fender side/5-window.
#92386 07/21/2005 4:38 PM | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | When I installed my new harness I had the same symptoms. I had wired my gas gauge to the wrong terminal on the ignition switch and the gauge was always on. Turn the key on and off while watching the gauge. Needle should jump with power.
Curt B.
1952 1300 Canadian 1/2 ton restomod You Tube | | |
#92387 07/22/2005 4:59 AM | Joined: Feb 2000 Posts: 987 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 987 | Frank you might try this (I have heard people use it to find shorts). Take some type of device like a seat belt warning buzzer and hook it up between the battery and the positive cable. As long as the drain is happening it will "buzz". Now just go through your fuses and pull one at a time. As soon as the bussing stops you have identified the ciruit that the "drain" is coming from. I have never tried this but is sounds good to me. Good luck and keep us posted.
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | |
#92388 07/22/2005 4:00 PM | Joined: Mar 2005 Posts: 16 Junior Member | | Junior Member Joined: Mar 2005 Posts: 16 | thanks for all your suggestions, I have tried them all (with some variations) switched gas guage (key activated), don't have radio, clock, or alarm, etc. But I may disconnect lighter to see if that is problem. Disconnect switch will be installed soon, until I find the problem...Frank | | |
#92389 07/23/2005 5:21 PM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Frank do you have a ampmeter of some sort?
With the truck turned off just like you were going to leave it overnight. Disconnect the positive cable from the battery and measure the current flow. Start with a high range and then work down until you have an accurate measurement. That way you should be able to know exactly what you are loosing.
Then with the meter still connected, disconnect one electrical device at a time until one of them makes the current flow go away. That one is the problem.
Best to approach it with some sense of structure, perhaps pulling a fuse, and if nothing changes assume everything on that fuse is okay. Remember that some circuits are not fused on an old truck, and your problem may be something that doesn't have a fuse. To find those located each junction, like at the starter, and disconnect each wire while checking for the current flow to go away.
Before you buy and install a disconnect switch, have you tried disconnecting the battery overnight to see if that affects it? Could be a bad battery...
Where in the Seattle area are you? I'm in Kitsap county.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
#92390 07/31/2005 5:00 AM | Joined: Mar 2005 Posts: 17 New Guy | | New Guy Joined: Mar 2005 Posts: 17 | quick question - what engine? any aftermarket options? BIG question - does it have stock or HEI distributor? original or later steering column/ignition switch? original or later wiring? when the engine is running, what is the voltage measured from the (+) battery post to frame ground? | | |
#92391 08/04/2005 10:53 PM | Joined: Mar 2005 Posts: 16 Junior Member | | Junior Member Joined: Mar 2005 Posts: 16 | hey hotrod.. stock 283 stock dist no options stock steering col and replaced ignition switch all stock wires. will check on voltage when running, but will loose .6 volts overnight. | | |
#92392 08/04/2005 11:57 PM | Joined: Jun 2005 Posts: 27 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 27 | could be some of the wiring insulation is breaking down allowing a partial short. will be difficult to find. Oldsub's suggestion of an ampmeter is a good one. moving wires with someone watching the meter you might get lucky. goodluck | | |
#92393 08/05/2005 2:50 AM | Joined: Jul 2005 Posts: 226 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2005 Posts: 226 | .6 volts overnight.??? from what to what..??? are you sure its a current draw..sucking it down...its normal for a batter to go from being charged to stitting to loose a little voltage... but that doesnt mean its gonna loose .6 accumulative every day...like ten days loose 6 volts... is that whats happening..??? or just the .6 volts one night..??? and is ur voltage meter right..???
What it will say on my Tombstone: "Boy, that guy sure owed alotta people Money"
