1 members (carbking),
77
Mod | | | Forums66 Topics128,196 Posts1,057,393 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2011 Posts: 305 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 305 | Is there a ratio gas to Methel, I can go by? I have a 84 VW Cabriolet I need to aircare.
John | | | | | Joined: Oct 2006 Posts: 843 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 843 | I think I remember putting 500ml to 30L | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | If you haven't already done so, I'd run a bottle of fuel injector cleaner through. Mohawk has that 10% ethanol blend fuel they sell - might be worth a try. | | | | | Joined: Sep 2011 Posts: 305 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 305 | Do you think they will let me raise the gvw on the VW to 5001? Haha. The thing runs fine but failed last time I tried. The car's not worth the mechanics bill it would take to make it pass. | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | I think there is a maximum $$ amount they can force you to spend, before giving you a provisional pass - where is it failing ? CO, hydrocarbons ? NO ? - might help you diagnose problem areas | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | you guys should just move to the Island  Bill | | | | | Joined: Oct 2006 Posts: 843 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 843 | Bill,may we all use your address for registration?  | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 |  sure - might be a question about the address difference 'tween your reggie and driver license tho' Bill | | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | What ever happened to no fixed address? Air Care is only going to be around until the end of the year thank goodness. What a money grab.
A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: Sep 2011 Posts: 305 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 305 | Air care ends Dec. 2014. I thought it was the end of this year but not according to the Air care website. | | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | What.......! The insurance person at London Drugs told me it ended at the end of this year. Harder to kill a cash cow than a cockroach. How did you do on your air care, have you tried again? A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | |
