7 members (wilbur53, Rusty Rod, D B Cooper, RaNfLaS, Gdads51, KEVINSKI, 1 invisible),
114
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,094 Posts1,056,060 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2010 Posts: 90 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2010 Posts: 90 | I have the chance to purchase the rear end and possibly the whole drive train out of a 1946. I would be putting it into my 1937. The 46 has the 3:55 gears in it already which is why I would be looking to use. How compatable is the 46 rear end with my 37? I'm not afraid of a little work to get what I want, just want to know what I would be getting myself into.
Thanks for the help, Charlie | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Is the 46 rear end a car or truck?
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Sep 2010 Posts: 90 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2010 Posts: 90 | Its a truck rear end with the original gears replaced with 3:55. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Is your truck 3 or 4 speed and is the 46 3 or 4 speed?
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Sep 2010 Posts: 90 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2010 Posts: 90 | My truck is currently a 3 speed, the other setup is coming of a 4 speed truck. I may be able to buy the 4 speed with the rear end. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I would not want to switch to a non-synchro 4 speed if it were me. I asked as if both your 37 and the 46 were 3 speeds because I would have suggested using the 46 trans to prevent U' joint problems if it had been a 3 speed. I think I should PM you my phone number to talk this over. There is to much info for my typing skills to write.
