Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (red450IH, 50Chevy3100, Stovebolt48, Steveoreno), 169 guests, and 2 robots.
Topics128,288
Posts1,058,581
Members48,492
V
V Offline
Have a 235 out of a 1960 truck /235. The mount is center below the harmonic balancer. My '57 had side mounts OEM. Considering swap to newer engine with better compression. Any idea hole size and location of hole in front crossmember. I could measure , looking for input. Any pros or cons to this front mount 235. Thanks a bunch
'57 3200
There's a template for the mounting holes in the tech tips. See here:
http://www.stovebolt.com/techtips/motormount_235.html
You Tube
