9 members (3B, BarryP, Ribside, DadsFirstPickup, Ol' Red, Donf, Biermann, Jon G, UtahYork),
142
Mod | | | Forums66 Topics128,134 Posts1,056,738 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2005 Posts: 56 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 56 | I am looking for suggestions on how best to remove the massive double row bearing that my 1-1/2 ton truck has on the outer end of the pinion. The manual suggests using a press plate like this: Pinion bearing removal plate I've looked high and low for one of these... Anyone know of a source, or an alternative that won't wreck my pinion during the removal?? Thanks in advance!
WW2Chevy 1942 Chevrolet G506 1-1/2 ton 4x4 Army Cargo w/ winch
(Retro-roco)
| | | | | Joined: Jan 2013 Posts: 603 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 603 | That press looks like any upside down bottle jack press. Most repair shops should have one. The plates look like just regular pieces of metal,placed in the correct position under the bearing. Actually if you have need for one often, your Chinese Tool Store has them pretty cheap.
57 GMC LCF 370 55 John Deere 40-W 59 John Deere 430-W 2000 GMC 4x4 56 John Deere 420-W Pix on Photobucket | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You will need a brg. separator also to get behind it. Most part stores will press it off for you. Or a shop will probably do it. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jun 2005 Posts: 56 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 56 | The flat plates and press are not the problem. The removal plate I'm referring to is the round plate shown in the inset of the photo. It has notches around the inner hole, to clear the pinion flutes so you can engage the inner sleeve of the bearing, rather than pressing just on the outer shell. I'll have to check at some of the big truck repair shops. The bearing itself is probably 5 inches in dia. and nearly two inches thick.
(Retro-roco)
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | A bearing separator as George mentioned is what you need. Any place that has a press should have one and can help you. I also would recommend installing a new bearing if you have the old one pressed off. Here is a picture of one. http://www.zorotools.com/g/00057375/k-G3325567?utm_source=google_shopping&utm_medium=cpc&utm_campaign=Google_Shopping_Feed&kw={keyword}&gclid=CIzg4J6T17UCFYpDMgoddhoAog | | | | | Joined: Jun 2005 Posts: 56 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 56 | Thanks for the input (and the link)guys!
(Retro-roco)
| | | | | Joined: Jan 2013 Posts: 603 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 603 | Sorry, I didn't pay attention to the inset pic. of the seperator. Maybe make one? When removing big bearings on the old 2 cyl. John Deeres, I have used an old "Arkansas Toothpick" its just a big ole hunting knife. I would use a hammer and drive it behind the bearing while moving it around the bearing. That thing was one of the most used tools in my toolbox. lol.
57 GMC LCF 370 55 John Deere 40-W 59 John Deere 430-W 2000 GMC 4x4 56 John Deere 420-W Pix on Photobucket | | | | | Joined: Jun 2005 Posts: 56 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 56 | This is a case of "much to do about nothing"... I realized (as Don Stocker pointed out) that I was planning to install a new bearing anyway. I used a propane torch to gently warm the inner bearing race, and then used my largest 3 jaw puller, and the old bearing came right off. I cleaned up the pinion shaft, and put it in the freezer. An hour to and hour and half later, I carefully warmed up the inner race of the new bearing(easy to do without the pinion shaft in the way). I warmed it up until the cosmoline melted and started to smoke a little. Grabbed the shaft from the freezer, prepared to beat it into place with my dead blow hammer. NO NEED! It literally dropped right into place, without so much as a single hammer blow. As the two pieces reached a common temperature, the bearing tightened up nice and snug.
I'm a happy man!
(Retro-roco)
