| | | Forums66 Topics128,046 Posts1,055,618 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2001 Posts: 95 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 95 | What is the correct type fastener for a 1948 voltage regulator to cab? Looks to be a sheet metal screw. Hex or clutch head? Is it a #12 screw?
The regulator was not installed when I got the truck.
| | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | Brad -
Were clutch heads also used in '54? My aftermarket 12v VR is mounted with hex head sheet metal screws. Obviously wrong.
I replaced my VR cover similar to the one in your pic with an old Delco Remy cover that I got from a fellow 'Bolter. It helps disguise the 12v elec system on my '54. (except for the hex heads)
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I'll check about clutch head being used in 1954, Lonnie.
| | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | I have a sizable collection of original and aftermarket voltage regulators. some of them have rubber grommets where the screws go thru, some don't. What is correct? Were there different kinds for different years? Was the rubber for vibration prevention?
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | A bit out of focus, but it’s a stock 1950, 3604, like Brad, clutch head screws: http://www.pbase.com/dennygraham/image/148984564 What I believe to be a stock 1954, 3604, slotted head screws: http://www.pbase.com/dennygraham/image/148984577 Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Yes Carl, rubber grommets for vibration isolation.
Dg
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | None of my Chevrolet truck and GMC 54/55 voltage regulator screws are clutch head.
All of mine have rubber grommets that the slotted screws go through.
| | | | | Joined: Feb 2001 Posts: 95 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 95 | I got to see before tear down photos of the '48 today. This truck was an original truck 3 years ago - original paint. The photos show pan head slot screws holding the regulator to the cab. This truck has a lot of slot screws where later years have clutch head. Maybe '47 & 48 had more slots form GM?? | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | There are two types of clutch screw drives: Type A and type G.
Type A, the original design, also known as a standard clutch head, it resembles a bow tie with a round center. These were common in GM automobiles, trucks and buses of the 1940s and 1950s. Type G resembles a butterfly. This type of screw head is commonly used in the manufacture of mobile homes and recreational vehicles and is the type that are being marketed to us from the vendors today. I don't know anyone who makes or sells the Type A now a days.
Your '48 would have had Clutch head screws as shown in the links above.
DG
| | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | Hey guys, Thanks for the info on clutch head vs slotted and for the explanation of the rubber grommets on my mounting bolts. The '47-'54 FAM shows slotted head screws to mount the VR. It's misleading for early AD trucks. An old post & pic on Stovebolt said that clutch heads were used in '54. Notice the difference in the location of the screws in the covers. The '47-'54 FAM and '54 Shop Manual show them through the top at two corners. I know that diagrams and photos are often shown for the wrong year.
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | Just to add to the fastener discussion, both the '50, and '49 'bolt, and my '49 Poncho used large Philips head screws to mount the regulators. Perhaps all were replaced!! | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Just to add to the fastener discussion, both the '50, and '49 'bolt, and my '49 Poncho used large Philips head screws to mount the regulators. Perhaps all were replaced!! or all are of Canadian manufacture  Bill | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Even though the FAM says, 1947-54 it is just meant to give you an over all idea of what went where. A good portion of the illustrations are primarily aimed at the '54 model years. You can't always tell if the same assembly ritual was followed for the earlier AD's. All of the AD’s that appeared to be original that I've seen follow the fastener application that we've been posting here. That is Clutch heads on the pre-54 models and slotted heads on the post-54 cowl electrical units. It would be very rare to find a 60-year-old vehicle that had the original VR anyway. Just because the cover says Delco Remy doesn't mean that it is still the original VR. They did make replacement parts also you know. Back in the day when I was working as a parts man, the VR was one of the more common parts that was often replaced along with rebuilt generators and starters, tires at 20k, points, plugs, cap & rotor at 8-10k. We're so used to driving 80-100k without opening the hood or kicking the tires now days that we forget that it took a heck of a lot more maintenance to keep these 50’s vintage vehicles on the road.
Denny G
| | | | | Joined: Apr 2005 Posts: 28 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 28 | [quote=Denny Graham] Yes Carl, rubber grommets for vibration isolation.
I've often wondered about that. As an electrician, I realize that they also isolate the Voltage Regulator from "ground".... | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Actually the regulator case is grounded on the right side thru the two mounting screws: http://www.pbase.com/dennygraham/image/149107869I believe the grommets are for vibration isolation only. Denny Graham Sandwich, IL
