0 members (), 171 guests, and 2 robots.
Topics128,143
Posts1,056,494
Members48,442
Wanting better hiway gears I just picked up a dana 60 with a 373 ratio from a 71 F250. The WMS is 3/4" wider than the stock Eaton so should work well. I do need to move spring perches and shock mounts. Do I need to have the housing aligned after welding the perches? I have read conflicting opinions on this.
Have things aligned before you weld. I use a tape measure and make an x from the front end. Once you weld, there is no adjusting.
