removed old mc off frame, install dual bowl mc,hooked up rod on end of mc, to long, cut about a 1/4 inch, fits now...question, is there suppose to be a certain length on rod to perform right?
Hy 696969, there must be a slight amount of clearance in the pedal/rod to allow the master cylinder to return to its at rest position, hope that helps.
