| | | Forums66 Topics128,064 Posts1,055,859 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2008 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2008 Posts: 55 | Working on my 53. Putting mono leaf springs on and lowered shocks. The front worked out fine but when I put the back togethere the shocks are too short. By about 5 inches! I have the weight off the suspension. I contacted CPP where I bought the shocks. They said to drop the truck down on the wheels. Which I did and they are still 4 inches away. Now I know I don't have all the weight of the truck on yet but I don't think I'm going to get that much distance. You should have to compress shock some to get it to install. With no weight on the front i had to compress the shock to install. Do I have to weight untill I have all the weight on the truck? That makes no sence. If I turn the shock mount upside down it will reach but that doesnt look right and the bracket is only 5/8 of an inch away from the tire. I have another shock mount bracket from a universal kit that I can mount lower on the frame and have to compress the shock about an inch and that's with the suspension hanging. What do you guys think? | | |
