1 members (2-Ton), 66 guests, and 1 robot.
Topics128,050
Posts1,055,646
Page 2 of 2 1 2
I'm sure it's just me, but none of Tim's links ever work for me.
My Blog
Hello,
Here is a photo album of a 1955 Chevy 1st series 1/2 ton truck with a Hydra-Matic
https://picasaweb.google.com/106723428487424188160/1955ChevyTruckBlue?noredirect=1
The Hydra-Matic in this truck has a Cadillac center case which means it is pan fed. Pan fed means there is a tube attached to the tranny oil pan to check and fill tranny from engine compartment. There is no side smoke stack filler on a Cadillac case. All internal parts are the same. Just the case is different.
The rear tranny cross member is there but not used for tranny support.
As you can see it has open drive shaft.
Hello,
1954 Frame spec, PDF page 90, Sheet page 129
http://www.gmheritagecenter.com/doc...hevrolet-Trucks/1954-Chevrolet-Truck.pdf
1955 Frame spec, PDF page 78, Sheet page 135
http://www.gmheritagecenter.com/doc...ucks/1955-Chevrolet-Truck-1st-Series.pdf
No change in frames from 1954 to 1955, but 3600 frame is beefer than 3100.
Go here click on Show to find above GM Vehicle Information Kits
http://www.gmheritagecenter.com/gm-heritage-archive/vehicle-information-kits.html
1955 1st with 4 speed manual, No rear tranny cross member
pic 1
pic 2
pic 3
I have some pics of 1954 with 4 manual tranny somewhere still looking.
jorb #925835 03/08/2013 5:10 PM
Hello,
Info from 1954 salesman data book.
1954 Chevrolet Truck Frames Specs
1954 Chevy Truck 3600, 3100 Frame comparisons Photo Drawing
Looks like there is a fairly big difference between the 3100 and the 3600 frames.
Hello,
Took me awhile but I found the 1954 Chevrolet 1/2 ton truck with 4 speed tranny .
No tranny rear support cross member.
Enclosed drive shaft.
Picture Album
Bonus: Old UPS 1954 Chevrolet 1 ton Panel truck with 4 speed tranny.
2 piece Open drive shaft with center intermediate bearing.
pic 1
pic 2
So, I went & wire brushed the rear end & found this stamped on it.
N K1224
Not sure if the "N" is part of it since its spaced kind like the way I typed it on here.
So what I'm trying to find out is what the gear ratio of this rear is.
I got it off of a 54 GMC Hydra-matic open drive.
Any info appreciated
Javier
Did that code come off a plate attached to the transmission?
If it did, what is the color of the plate?
Originally Posted by RaNfLaS
So, I went & wire brushed the rear end & found this stamped on it. N K1224 Not sure if the "N" is part of it since its spaced kind like the way I typed it on here.So what I'm trying to find out is what the gear ratio of this rear is.I got it off of a
Javier
What tonnage/series is the truck.
The color of the ID plate would ID the size (if it is a 1954 H-M transmission):
At this link are GMC tag colors for different sizes of 1954 Hydra-Matic transmission. Chevrolet 1954 H-M tag colors are the same as GMC tag colors on 1/2 (3100 or 100 series), 3/4 (3600 or 150 series), and 1 ton (3800 or 250 series) transmissions.
If it has an open driveshaft, and if it is a 1954 GMC Hydra-Matic transmission, it would have to be from a 3/4 ton or larger truck.
I appreciate all the help, but unfortunately all I have is the rear end from this 54 GMC Hydra-Matic truck.
No trans or color tags to work with just the rear axle.
Ive had it sitting in my back yard for some years. What Im trying to figure out is if this rear end will allow my truck to drive at 60MPH-70MPH?
If GMC rear-end codes are the same as Chevrolet codes:
NK 1224
NK = 1955 1/2 ton rear-end from the Detroit assembly plant
12 = December
24 = 24th
If that is correct, it would be a 3.90:1 rear end (open drive-shaft).
Page 2 of 2 1 2
