I've read of, and have had a problem with replacing the alternator on the 292. The alternator pulley on a 292 is particular to the 292. The alternator went out on my 292. I grabbed another alternator lying around the shop, looked the same. Installed the spare alt, didn't line up, didn't see the problem. Went to the FLAPS and bought a rebuilt for a 292, didn't line up. Finally took a close look and replaced the pulley, problem solved. the alignment is of by 3/8 to 1/2 inch. I would think that with the 230 parts on the front of the 292 there shouldn't be a problem, but,,, you changed the harmonic balancer to a 292. Now you need the Alt pulley, and water pump pulley. My best guess. :^)
larry
