4 members (Gray_Ghost, IHPWR, Rusty Heaps, FAST55), 61 guests, and 3 robots.
Topics128,026
Posts1,055,404
Members48,422
#920610 02/17/2013 7:06 PM
i need some hep guys .. i been told that i need to adjust my valves when engine is hot ,,, my problem is when motor is hot they are fine , its only when i start it cold that they are loud ,,, can i go out after it sits for a few days and adjust them then and will they be ok that way and not too tight after it gets hot ??
thanks
p.s. its on my 1958 biscayne 235
1958 chevy biscayne
235 6 cyl 1 barrel
2 speed PG tranny
lilrobo #920612 02/17/2013 7:09 PM
Hydraulic lifters - right?
lilrobo #920614 02/17/2013 7:17 PM
yes
1958 chevy biscayne
235 6 cyl 1 barrel
2 speed PG tranny
lilrobo #920697 02/18/2013 7:26 AM
Sounds like the lifters are bleeding down when the car sits.
lilrobo #920746 02/18/2013 10:13 AM
Every hydraulic lifters that is holding a valve open bleeds down when the engine is off.
With new lifters some can have too tight of a clearance between the piston and the body and they can stick in the collapsed position until the lifter warms up. Once warm the body expansion releases the piston and the lifter will work normally. Over time this type of problem will go away as the lifter wears in.
If this is a used lifter the same problem can occur because off sludge build up inside the lifter causing it to stick.
My Blog
lilrobo #920761 02/18/2013 11:00 AM
so you saying do nothing right now ?? or adjust them again cold or hot
thanks
1958 chevy biscayne
235 6 cyl 1 barrel
2 speed PG tranny
lilrobo #920813 02/18/2013 1:29 PM
I had the same problem. After sitting a little my lifters were noisy as heck. They quiet down and stay that way after driving a little.
lilrobo #920817 02/18/2013 1:48 PM
Run it some. How many miles since you had it rebuilt?
lilrobo #920827 02/18/2013 2:18 PM
If the lifters are sticking when cold you definitely want to adjust them hot.
My Blog
lilrobo #920897 02/18/2013 6:27 PM
Just the ticking when cold it driving me crazy lol
1958 chevy biscayne
235 6 cyl 1 barrel
2 speed PG tranny
lilrobo #920904 02/18/2013 6:38 PM
Don i would say 500 maybe a little more
1958 chevy biscayne
235 6 cyl 1 barrel
2 speed PG tranny
lilrobo #920934 02/18/2013 7:54 PM
Turn up or install a radio grin
My Blog
lilrobo #921508 02/20/2013 8:03 PM
I think i am going to give it 1 mote shot to adjust them, , the book says 1 1/2 turns after 0 lash, ,, now 0 lash is were there is no more play in the pushrod?
seems like a lot 1 1/2 more? ?
thanks
1958 chevy biscayne
235 6 cyl 1 barrel
2 speed PG tranny
lilrobo #921524 02/20/2013 8:43 PM
Yes zero lash is no play and you can hear it. 1/4 to 1/8 turn at a time, or less when you get close and wait a few seconds until the lifter settles to be sure. I've always done hydraulic lifters while running and hot. Low idle though or you are going to need a bath in solvent.
If your engine is cold and you adjust, you may get an over tight condition when it gets hot.
I'm a V8 guy, maybe a 6 guy can confirm.
lilrobo #921540 02/20/2013 10:00 PM
It is to hard to keep a screw driver on the adjuster to adjust the when running, completely different than a V8.
I know it has been argued that 1 1/2 turns is to much, but Chev set them that way for 12 years (1950-62). I have been setting them that way for close to 40 years with no problems.
My Blog
Pre '68 Dave #921548 02/20/2013 10:49 PM
So there ya go, silly me. I'm thinking modern lock nut you just torque.
lilrobo #922091 02/22/2013 8:07 PM
found this
http://www.cs.siena.edu/~lederman/truck/Docum ents/...
have i been doing them wrong all these times ?? i was finding TDC #1 and doing 1,, and so on ,,, it says here #2 and 3,4,5 are not done at the same time ,,, could this be the reason i have loud lifters when cold they are not done right , i was doing the intake and exhaust at the same time ???
??thanks
1958 chevy biscayne
235 6 cyl 1 barrel
2 speed PG tranny
lilrobo #922093 02/22/2013 8:39 PM
Your link is broke so we have no reference to your comment.
At TDC for every piston both valves will be completely closed. So you would adjust each at the same time. Unless there is something I don't get about a sixer.
lilrobo #922102 02/22/2013 9:05 PM
I was doing the intake and exhaust at the same time
That is the way I do it. You just need to be sure the valves you are adjusting are both closed. The easiest way for a novice to confirm this is by adjusting the cylinder/plug wire the rotor is pointing at.
My Blog
lilrobo #922159 02/23/2013 5:10 AM
So with the rotor button pointing at the correct plug wire, that cyl the valves are closed and do them both at the same time? !,, here is the link it works for me http://www.cs.siena.edu/~lederman/truck/Documents/Adjustment%20of%20valve%20lash.htm
It shows doing 2345 seperate looks like?
1958 chevy biscayne
235 6 cyl 1 barrel
2 speed PG tranny
lilrobo #922170 02/23/2013 7:15 AM
...link...
Here is another
...link...
Both those processes that've you place #1 at TDC then set 6 identified valves
1 Exhaust
1 Intake
2 Intake
3 Exhaust
4 Intake
5 Exhaust
Then place #6 at TDC and set the other 6 listed valves
6 Exhaust
6 Intake
5 Intake
4 Exhaust
3 Intake
2 Exhaust
If you followed the instructions you should be ok. Set the clearance to the type of lifter you have. The second link has some notes for hydraulic
lilrobo #922198 02/23/2013 9:22 AM
Yeah thats the link, , see there 2,3,4,5 are set set at the same time?
I might be getting somewere now
1958 chevy biscayne
235 6 cyl 1 barrel
2 speed PG tranny
lilrobo #922228 02/23/2013 11:13 AM
how that being said ,, i have been reading that not to do 1 1/2 like the book says.... i was thinking about doing like 3/4 ??
thanks
1958 chevy biscayne
235 6 cyl 1 barrel
2 speed PG tranny
lilrobo #922445 02/24/2013 7:22 AM
so is 1 1/2 turns too much ??? past 0 lash
1958 chevy biscayne
235 6 cyl 1 barrel
2 speed PG tranny
lilrobo #922502 02/24/2013 10:34 AM
It wasn't for the designers.
The truth is anything from 1/8 turn to 1 1/2 is OK.
1 1/2 turns will take up for wear a lot longer.
My Blog
lilrobo #922534 02/24/2013 12:58 PM
when i was doing the valve today , i turned off the motor and getting reading to install valve cover and i heard the weirdest noise sounded like water sloshed from the radiator like it had air and it all settled ??? whats that ??? air trapped in there ?
thanks
1958 chevy biscayne
235 6 cyl 1 barrel
2 speed PG tranny
lilrobo #922545 02/24/2013 1:58 PM
Did you drill a 1/8" hole in the thermostat "disc", to allow circulation of at least a little coolant at all times? That is one way to minimize/eliminate air trapped in the head.
lilrobo #922551 02/24/2013 2:16 PM
ohh no i didnt , i know we had a Toyota truck once and it got air in the system ( leak in head gasket ) and it caused it to run hot ,,,,,, so would that have something to do with that also ?? so i guess i should do a 1/8 huhh
thanks
1958 chevy biscayne
235 6 cyl 1 barrel
2 speed PG tranny
lilrobo #922556 02/24/2013 2:25 PM
The last 180 thermostat I purchased came with a check valve build into the housing, so you didn't have to drill a hole.
...pic...
I believe it was a Mr Gasket
Here is my 160 that I did drill
...pic...
lilrobo #922581 02/24/2013 3:59 PM
i dont know if the one that in installed had a hole or not ,, i'll have to see , would that cause it to run a little hot ??
1958 chevy biscayne
235 6 cyl 1 barrel
2 speed PG tranny
lilrobo #922586 02/24/2013 4:26 PM
Trapped air could
Have you check your fluid level?
lilrobo #922657 02/24/2013 7:32 PM
Yeah i checked after it cooled it was about 1" down, were is always is, got me i may have to drill a hole in stat
1958 chevy biscayne
235 6 cyl 1 barrel
2 speed PG tranny
lilrobo #922746 02/25/2013 8:56 AM
All good this morning no nosie on lifters and it was cold here
Maybe this time they are right
1958 chevy biscayne
235 6 cyl 1 barrel
2 speed PG tranny
lilrobo #922749 02/25/2013 9:08 AM
Glad to hear you are getting things in order. The more you run it and get it broke in the better its going to run.
lilrobo #923297 02/27/2013 9:23 AM
what should i set the lash at to get the 216 started for the first time
