| | | Forums66 Topics128,029 Posts1,055,417 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2012 Posts: 23 New Guy | | New Guy Joined: Oct 2012 Posts: 23 | I have a 52 Chevy 3800, 216 engine with Rochester single barrel carb. I purchased and installed new Choke and Throttle cable assemblies. My problem is that the accelerator return spring will not allow the throttle cable to remain in the pulled state. As soon as I release the throttle cable knob, it returns to the dash. What am I missing? Thanks, Jim | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the repro cables have that feature .... I think the only fix is to 'crush' the rigid housing just behind the dash to create more friction - or get a wimpier return spring  Bill | | | | | Joined: Sep 2001 Posts: 581 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 581 | I second Bill. If your new cable is long enough, try putting a loop in it, to give enough friction to hold the core against the spring. It's a matter of introducing enough resistance so it holds itself. I've often wondered why they (presumably) worked so well from the factory, but are hard to get right now-a-days.
-Michael | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | A lot of the times I put some small kinks in the inner cable to provide some extra friction.
See the USA in your vintage Chevrolet! My Blog | | |
