0 members (),
129
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,115 Posts1,056,292 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2012 Posts: 103 'Bolter | | 'Bolter Joined: Aug 2012 Posts: 103 | I bought a fiberglass headliner for my '38 half ton. I'm not sure how best to finish it. Is regular paint alone a good option, and if so, does anyone have any experience with the results? Thanks. | | | | | Joined: Dec 2012 Posts: 97 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2012 Posts: 97 | Once you get past the surface prep, you can use any paint you want. Depending on the quality of your piece it can take some blocking to get it to not look like wavy glass. Many parts come out of the mold to quickly or uneven and as it cures it shrinks. The surface can be slightly undulating and fibers exposed. We use to use a high-build two part polyester spray on filler to adhere, seal and prep as an under coat over glass. I don't know what is available today but you get the idea. Otherwise paint away. | | |
