4 members (cmayna, EddieD, 2 invisible),
47
Mod | | | Forums66 Topics128,009 Posts1,055,291 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#92241 06/29/2005 12:28 AM | Joined: Feb 2005 Posts: 399 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2005 Posts: 399 | FedEx just showed up with my Pertronix Igniter and coil..They say I can open up the gap on my plugs after I install their system..It's a 235..Has anyone done that, or should I just keep them at .035? Thanks, Steve | | |
#92242 06/29/2005 2:24 PM | Joined: Feb 2005 Posts: 60 Member | | Member Joined: Feb 2005 Posts: 60 | Steve i have never used there coil but do use the igniter in my 235. I have kept the plugs at .035 with good results. Your not going to believe how easy it will start. Might get 2-3 mpg also. | | |
#92243 06/29/2005 2:30 PM | Joined: Feb 2005 Posts: 399 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2005 Posts: 399 | My new Igniter and Flamethrower coil is installed, and I can't believe it fired right up and purred like a kitten..Thanks to all for the advice, and for the confidence in this product..I also recommend it highly.. DJ..I'm gonna keep the plugs at .035..Thanks Steve | | |
#92244 06/29/2005 6:26 PM | | Anonymous Unregistered | | Anonymous Unregistered | I'm running two Pertronix units in my trucks(a 235 in my '37, and a 261 in my '59). I opened the plug gap up .005" to .040" as Pertronix recommended and I think it helped a little. May be a placebo effect though. | | |
