Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (WICruiser, Joe H), 148 guests, and 5 robots.
Topics128,283
Posts1,058,513
Members48,490
#922321 02/23/2013 5:17 PM
Anybody know if chevy electric wiper motors came as 1 or 2 speed in 59? I have a stock wiper motor and an aftermarket 2speed switch I can only get 1speed to work. The wiper motor wiring is oem from he motor to the switch
the OEM 55-59 wiper motors were mechanically controlled, the wires should go directly to the motor, a cable to the motor from the knob moves a switch in the motor that gives 2 speeds ... by using the aftermarket electric switch, you're only getting what ever speed the mechanical switch in the motor is set to, high or low - only pic I have right now, the rusty part is the cable clamp .... the proper switch is not available repro AFAIK
