5 members (Wayne67vert, 52Carl, Otto Skorzeny, Steelonsteel, klhansen), 101 guests, and 1 robot.
Topics128,113
Posts1,056,613
Members48,450
#921967 02/22/2013 11:44 AM
I am converting my '66 from a manual transmission to an automatic. Has anyone who has done this conversion found a good way to plug up the hole in the firewall for the clutch rod? I know I could just put in the clutch boot and seal up the little hole but I was wordering if there is a better way. Perhaps someone found a grommet that fits? Any other ideas? Thanks.
NAPA will usually have a variety box of rubber grommets that includes some without holes [plugs], might check that - also, electrical parts suppliers have various size metal plugs for junction boxes that might work .... be creative
I made a plate using sheetmetal and attached with two screws. OE automagic trucks had either a plate or an oblong plastic plug.
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
I'll take a look at the grommets at NAPA but unfortunately the hole was not simply punched out but has a 1/8" or so rolled edge for the boot installation which means most gromments I have won't work.
OE automagic I am unfamiliar with . . .
frostplug?
ron
Originally Posted by padresag
frostplug?
ron
Now there's an idea. I'll have to see if I can find one large enough.
MIG welder....
R-Bo
1966 GMC 305V6 in the family
The factory plug is:
Caplugs #B-385
We have a few good, used ones, if you are looking for a factory-correct solution, to remedy the issue.
