2 members (Stovebolt48, 1 invisible),
131
Mod | | | Forums66 Topics128,211 Posts1,057,473 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2012 Posts: 112 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2012 Posts: 112 | I just got back from a 4 mile run on the back roads with betsy and she runs well.(Boy does this takes me back).outside temp was 19 degrees here this morning.Never shut her down the highest running temp i got on the new gauge was 165. Any one got any ideas why she does not top off at 180+-. maybe wait till summer. my son in law has one of those laser pointer things.He will be up for Easter.Real luke warm heat. | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | Out west here we slip a piece of cardboard or buy us some fancy radiator bra's like them big rig's use to put in front of the radiator when it gets cold like that... Who wants to wait for summer?
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the thermostat sets the minimum temperature the engine can run, it doesn't 'top off' higher because it's too cold out - sounds like you have a 160 thermostat, you need a 180 for winter driving
Bill | | | | | Joined: Feb 2007 Posts: 435 'Bolter | | 'Bolter Joined: Feb 2007 Posts: 435 | I have the same issue with my 230 in the 64'. Part of my problem is due to having a new radiator built with 3 rows instead of the original 2 rows, and efficency coming into play. It's been really cold here(in the teens) and several feet of snow on the ground, so I just cover part of the radiator with some cardboard much as I did when I had the KW. Without it the heater is working overtime to just barely keep frostbite to a minimum. Tramp | | |
