2 members (46 Texaco, Hotrod Lincoln), 165 guests, and 1 robot.
Topics128,119
Posts1,056,313
Members48,439
#921701 02/21/2013 3:21 PM
How many rubber pads do you use on a 1953 short bed? There's 4 blocks total, right? Two on the front panel sides and two on one of the crossmembers. Do you use 6 pads, one for each block plus the rear cross sill under the tailgate? I've seen different aftermarket vendors sell differing amounts for the same bed.
'53 Chevy truck 1/2 ton
4 wood blocks,6 rubber pads
Good bed details here, and BC52 is correct on the numbers.
http://www.mar-k.com/installation_hints.aspx
