| | | Forums66 Topics128,115 Posts1,056,288 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2001 Posts: 71 Shop Shark | | Shop Shark Joined: May 2001 Posts: 71 | How many rubber pads do you use on a 1953 short bed? There's 4 blocks total, right? Two on the front panel sides and two on one of the crossmembers. Do you use 6 pads, one for each block plus the rear cross sill under the tailgate? I've seen different aftermarket vendors sell differing amounts for the same bed.
'53 Chevy truck 1/2 ton
| | | | | Joined: Oct 2006 Posts: 843 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 843 | 4 wood blocks,6 rubber pads | | |
