2 members (Hotrod Lincoln, Shade Baby), 66 guests, and 1 robot.
Topics128,157
Posts1,056,875
Members48,458
I have a 1951 1/2 ton pickup with a passenger side door lock without a key. Is there anyway to ID the required key that works this lock?
Remove the lock assembly and take to your local lock smith
There is a 4 digit key code stampped on the housing
They should be able to cut a new key for you from that.
Thanks for the info
