5 members (Hotrod Lincoln, Chip O, greenie-reddy, rfs56trk, ole green), 89 guests, and 10 robots.
Topics128,077
Posts1,056,013
Members48,433
#921557 02/20/2013 11:10 PM
Does anyone have the width of the bed wood for a 1946 1/2 ton?
Mar-K was helpful with telling me there are 7 Boards in the 46 and how long they are but would not disclose the width.
I see from photo's that the center board is wider than the others.
I hope you can help me with this question.
BED BOARDS
X X X X X X X
1 2 3 4 5 6 7
How wide is the center board (4) and the boards on each side of center (3 & 5) ?
Then boards 1, 2, 6, 7 ?
Thank you very much for your help.
I'm sure others will appreciate this info also.
Harold
Harold
Harold.....I think your '46 is same width inside box as my '40 ?
I will measure mine later today and post. In the interim, if you have original cross-sills, you could measure bolt spacing ?
1940 Chevy KC 1/2-Ton
Britcom,
It is not the bed width I need, it is the individual board width.
My understanding is the 1940 - 45 had 6 boards and the 1946 had 7 boards.
Harold
Harold
Harold...didn't realize there are ( 7 ) planks on the '46
For what its' worth on my '40, inside overall width of the bed is 48 5/8". ( 6 ) planks - 8 3/4, 7, 7, 7, 7, 8 3/4
Harold, did you by chance find out the board width on a 1946 bed. I am redoing one myself and I am scratching my head. thanks. Tim
There was a website posted on here a long time ago showing the width of the boards for different years of Chevy trucks. I'll try and dig it up if I get a chance.
My 46 GMC on Photobucket
If you guys have the original bed cross sills, the hole centers would give you an idea of the board widths and positioning ?
Otherwise, I think Mar-K's website has board dimensions and details.
OK Fellows, here's what I did on my 46. These widths fit the original cross sill holes. 7 1/8" 5 1/2" 5 1/2" 9 1/8" 5 1/2" 5 1/2" 7 1/8"
Hope this helps
George
George,
Quote
Thanks, this is what I was looking for.
Harold
shake
Harold
I'm trying to refurbish the bed boards on my '46 1/2 ton. Someone here already pointed out that my back fenders aren't true to a' 46...and then I come here to get the dimensions and realize that the exact dimensions posted for a 46 = 7 boards. Mine clearly has six.
1) What year range would that make my bed?
2) Does anyone have the dimensions for the six boards?
Thank you in advance!
1946 Chevy
Getting started on Bruno
You can't buy happiness but you can buy a truck ... and that's pretty much the same thing.
O Online: Content
I might be confusing your truck with another similar post from several months back. If it's the same post, I thought it was determined that the entire bed and fenders were from another truck - probably not a Chevy.
1950 Chevrolet 3100 (Ol' Roy)
@46 Chevy truck.
What Otto said.
I'm not real familiar with the 46 beds, but I see on your pic, that your bed has tab sticking out each side for the tailgate chain hooks. I know on AD (47-55) trucks, the holes for the hooks are forward of the rear edge of the bedside.
What are the overall inside dimensions on your bed? A 46 Chevy bed would be 48.5" inside width and 78" inside length (front panel to tailgate.)
There was a discussion in May 2022 about this bed it appears.
https://www.stovebolt.com/ubbthread...y-46-chevy-truck-please.html#Post1454364
The bed on my ‘37 Chevy 1/2 ton was replaced by a previous owner. It has six boards each 3/4” thick and 76 inches long. Four boards in the midle measure 7 7/16” wide. Each board on the outsides measure 7 3/4” wide. A photo is attached.
41-45 have 6 bed boards
U
U Offline
I used these measurements for my '46, but ended up changing the outside boards to 7 1/2".
~ John in Utah
Here We Go
Follow in his DITY Bay
