| | | Forums66 Topics128,010 Posts1,055,299 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2011 Posts: 118 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 118 | want to run line from battery to headlight switch, what inline fuse should i use? | | | | | Joined: Sep 2003 Posts: 200 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 200 | What are you working on? Mark
1951 Chevy 3100 Some days you get the bear. Some days the bear gets you.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | want to run wire from battery to headlight switch, what size inline fuse should i use? this has been double posted | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | get a wiring diagram for your year here .... lights are fused at/by the switch, there is no fuse used in the headlight supply line Bill | | | | | Joined: Oct 2011 Posts: 118 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 118 | thanks again for info...pete | | |
