| | | Forums66 Topics128,037 Posts1,055,466 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#92126 06/14/2005 7:04 PM | Joined: Feb 2005 Posts: 399 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2005 Posts: 399 | Here we go with the gas gauge thing again..Been trying to get mine working and have previous threads..Anyway was just cleaning the glass and bezels on my gauges, and noticed the needle on my gas gauge would bounce a little depending on how hard I was rubbing..So, I hit the top of the dash, and the gauge would jump to full and back..Is this something that should happen, or does it really mean my gauge is fried from being hooked to 12V without a reducer for a while by PO? | | |
#92127 06/14/2005 7:11 PM | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | dont know for sure but I would think it should not jump when bumped...I tried that once when I ran out of gas, still would not start,,,just kidding,Fred Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | |
#92128 06/14/2005 7:47 PM | Joined: Feb 2005 Posts: 399 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2005 Posts: 399 | I agree Fred,,tried to get mine to read before when I was out of gas..I believe it might have to go to the Big Fuel Gauge in the Sky..Maybe I can hook it up to the CD player and get it to bounce with the music | | |
#92129 06/14/2005 8:02 PM | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | The one thing that I do know about these fuel gauges is that when I was looking for my AD truck it was not un-common to find the fuel gauge did not work,, all had been converted to 12 volts,,,like I said before I just got tired of trying to trace the problem down and installed one under-neath between my ignition and glove box, found 2 screws in the right place and just mounted it there,did not even wire it up to the ignition, just wired to the coil side of the dist....again trying to stay away from under the dash as much as possible, my neck does not like the kind of work.. Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | |
#92130 06/14/2005 8:07 PM | Joined: Feb 2005 Posts: 399 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2005 Posts: 399 | I agree with the neck thing..too old to be a pretzel..Stewart Warner gauges look good..Did you say you got a sending unit from too, or can I just get a gauge that covers 30ohms? | | |
#92131 06/14/2005 8:13 PM | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | as long as they both match up they should work, I just wanna to make sure, got mine from the good ole NAPA store,,,just make sure they match,,I had to redo mine because the sender was in the incorrect box, so make sure they match.......mine was just a weird error,I think that I paid around 65 bucks for the two..good luck with it,,Fred Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | |
#92132 06/14/2005 8:28 PM | Joined: Feb 2005 Posts: 399 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2005 Posts: 399 | Thanks Fred..Got a neighbor that works for Napa | | |
#92133 06/19/2005 2:48 PM | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | Gents, Typical problem with AD fuel gauges is simply poor grounding, unless the gauge itself is really fried. It can be very time consuming to resolve this problem but once you find it, there's nothing like a work original gauge. When going from 6-->12 you need a reducer like the Runtz between the hot lead and gauge.
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
