| | | Forums66 Topics128,076 Posts1,055,922 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2012 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2012 Posts: 50 | I think this may fall under "now it is broke are you happy?" I have a 48 3600 that i just had aligned and runs great and handles well (but not like a modern truck of coarse ),,...assuming that it just came off the assembly line and is perfect for its original design, is there any real benefit to modern shocks as compared to the original knee action shocks, and are sway bars needed at all if you are running a 6 cylinder engine with 85 to 150 hp with a 4.56 rear and radial tires at 55 mph. Just wondering how many of us are feeling the need to put these on our trucks and what if any change we should expect . thanks | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | The knee action shocks are just as effective as a tube shock IF, and I repeat, IF they are in good shape and are maintained, which I might add, most are not. The advantage of the later tube shocks is that they are inexpensive, and can be replaced in a few minutes. The anti-sway bar up front makes a world of difference. The truck will feel much more solid. They eliminate most of the roll in the corners and I would thank the lordy that I had one if I had to make a sudden lane change at hi-way speeds. Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Aug 2012 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2012 Posts: 50 | thanks denny
I noticed on your pictures that are available on this website that you fitted your 3600 with modern shocks and sway bar. since mine is a 3/4 ton too, i was interested in how you made it fit. are the kits the same for 3/4 and 1/2 ton or do you need to drill the holes a little larger to fit as in the pics. also is a rear sway bar necessary and which after market kit would you recommend, also are we talking gas shocks many thanks | | | | | Joined: Apr 2009 Posts: 554 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 554 | I have no experience with the knee shocks but I sure agree with Denny about the anti-sway bar. Even at 15-20mph around corners it makes a big difference.
Chuck | | | | | Joined: Aug 2012 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2012 Posts: 50 | thanks denny and hookalatch
I just ordered the sway bar, shocks and mounts for the front and after i get it all installed will let you know how it rides.
thanks again | | |
