| | | Forums66 Topics128,070 Posts1,055,896 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 54 'Bolter | | 'Bolter Joined: Jan 2009 Posts: 54 | I am restoring my 1969 chevy c10 250 6 cly with 11 1/2 inch shoes. The e-brake strut lever is missing on both sides. I found new ones for other vehicles but not mine. They do belong in there don't they? How many trucks are the same? Getting frustrated | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The rear brakes on the 1/2 tons are essentially the same all the way up to '87. The later one should work just fine. You may need to ask for an "equalizer bar", as it is listed that way in some catalogs. Yes, it is needed, the parking brake will not work without it.
Bill Burmeister | | |
