1 members (crenwelge), 168 guests, and 3 robots.
Topics128,285
Posts1,058,274
Members48,483
#920837 02/18/2013 2:46 PM
I'm looking at a K10 long bed with a v8 and I have some questions
My front axle is disassembled. are parts still available for the front end?
is the steering box same or different between a c10 and a k10
on a k10 is the frame the same between a six and an eight cylinder engine vehicle?
the trans fer case is devorced from the tranny (420) what transfer case was used in these trucks and are parts for them still available.
what would I look for when inspecting a truck like this befor buying it. I know the basics
what was the rear end ratios that were standard for thes trucks.
any experts on this site who I can pm/email/ phone call to discuss the details of these 60-61 k10's?
thanks in advance
mike
My front axle is disassembled. are parts still available for the front end? - Most of the parts are still available, to service & maintain the front axle, but they may a bit prove elusive.
Is the steering box same or different between a c10 and a k10? - The two wheel drive and 4x4 manual steering gear boxes are different and not interchangeable.
on a k10 is the frame the same between a six and an eight cylinder engine vehicle? - The frames are essentially the same, but the front engine cross member on the early ('60-'62) and the cantilevered frame-to-engine perches on the later ('63-'66) Chevy 4x4 trucks, are slightly different and not interchangeable.
The transfer case is divorced from the tranny (420) what transfer case was used in these trucks and are parts for them still available. The Rockwell/Timken T-221 divorced transfer case was used on the '60-'66 Chevy K10 & K20 trucks & Suburbans. There are a number of aftermarket 4x4 parts suppliers, still selling rebuild kits for these transfer cases.
What would I look for when inspecting a truck like this before buying it. I know the basics. Is it a true "K" tag truck, meaning does it have the factory-correct K in the VIN tag identification and does the last eight alpha-numeric characters of the VIN match, those found on the top, driver-side frame rail flange.
what was the rear end ratios that were standard for thes trucks. The early 1/2 ton, 4x4 trucks ('60-'62) were 3.90:1, as standard equipment, in the K10 and 3.73:1, as standard equipment, in the K10 trucks from '63-'66.
any experts on this site who I can pm/email/ phone call to discuss the details of these 60-61 k10's? - Joek3167, on this site, is your man, when it comes to '60-'62 Chevy K10/K20 trucks.
Pm me and i will give you all the info on your truck and where to buy parts
my trucks vin is 1K154K10xxxx
The truck Id plate indicates its a:
GVW----------5600 lbs
Trim---------STD
Paint--------RPO-710A
Wheel base---127
the trucks Vin indicates its a 1961 long wheelbase 4x4 from kansas city. I get that.
the vehicle ID Plate, located inside the cab on the driver side kick panel confirms its a half ton.
the wheel base is 127 which is a long bed
The trim is STD, which is presumably "standard"
the paint is RPO-710A. It could be PPO but I'm pretty sure its RPO.
the 710 is a 1960 color code for Tartan Turquiose, would the 727 tampico turquiose color code for 61 be the same?
What does the "A" stand for?
with a VIN of 10XXX for a 61 I'm betting its an early 61 truck made in late 1960 which might explain the 1960 710 color.
But what does the "a" mean.
How do I post pictures?
Its a factory v8 truck but pretty sure its not the origonal engine. looks like a late 60's sbc.
Its a long bed fleet side bed on the truck.
needs lots of work but so does my life
Wish I could post pictures.
Thanks guys for all your help
REGULAR PRODUCTION ORDER A, means a solid color truck and you need a photobucket account or a flickr accountto be able to copy and paste pics on here
mike16 #921247 02/20/2013 12:04 AM
Both tony and joek3167 info is correct. As stated 710 is listed as a 1960 color with 727 as the 1961 color but your theory of early 61(actually built in 1960) may well be correct. Sounds like a cool project anyway. These old K10s are few and far between and very neat. You might check and see if the build sheet is in the seat or the protecto plate is in the glovebox and see what they say for the color code. If you have any questions fill free to email me at the address below. I have a large collection of factory sales brochures, service manuals and other info for these trucks. Good luck with your new project,
65 K10 Longbox Fleetside Big Back Window Custom Cab
65 K10 Flatbed
Old School Parts 60-66
(208)946-6173
[email protected]
