| | | Forums66 Topics128,268 Posts1,058,394 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2012 Posts: 62 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2012 Posts: 62 | My '50 3100 has headlights, and a single dim 6V taillight. I would like to add a pair of taillight / running lights at the rear.
Should I just get a set of trailer lights from the auto parts store and put 6v bulbs in them?
Can I wire them to come on when I pull the headlights switch?
How complicated is it to wire in turn signal indicators, and should I do this at the same time?
Thanks - Dickson
1950 Chevy 3100 short bed 1951 GMC 3/4 ton long bed | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | I think the easiest way to add turn signals would be to purchase one of the kits that attach to the steering column. Would be period correct, comes in 6v, and includes wire, flasher unit, etc. First thing to check with " dim " lights is your grounds. Make sure you have really good contact
| | | | | Joined: Jan 2013 Posts: 2,239 Moderator: Interiors, Texas Bolters, Name that Part | | Moderator: Interiors, Texas Bolters, Name that Part Joined: Jan 2013 Posts: 2,239 | Dickson, I went to the auto parts store and used a trailer light harness so that i can use my tail/running lights as blinkers also instead of needing to run extra bulbs. I am using a 3 wat switch for my blinkers. I found a set of headlamps that have LED blinkers hidden in them. I thought that they were kind of cool. I am prepping to convert mine to 12V in the near future. http://www.chevsofthe40s.com/detail/33295/Headlight_7_With_Halogen_Bulb_Amber_Led_Park.htmlHope that this helps! | | | | | Joined: Oct 2012 Posts: 62 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2012 Posts: 62 |
