1 members (Hotrod Lincoln),
118
Mod | | | Forums66 Topics128,093 Posts1,056,474 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | Anybody have a recommendation for the best way to support the rear of the vehicle, stands under the frame or under the rear end? I know the torque tube needs to drop down so the transmission can be removed up thru the floor if needed. Thanks Don | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | I supported my on the rear frame.
I did not have to remove the transmission replace the ball collar seal.(not sure if you have other work going on)
also placed a stand on the tube once I lowered it with a Jack stand.
