Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (TexasFarmTruck, crenwelge, Mike1933, tclederman), 227 guests, and 6 robots.
Topics128,282
Posts1,058,496
Members48,490
#920056 02/15/2013 1:52 PM
I got the opportunity to purchase a fresh 292 with a T5 bolted to it recently. I've read somewhere that the T5 might be too light to handle a 292 but I know there are some people using this combo. I'm interested in hearing from some folks that have experience with this. It'll go into a '59 swb for normal driving, no racing. I don't plan to use it for towing but you never know what need might come up. I also have an MY06 that needs some tlc to make it ready. Would it be a better choice for this engine? Any info from those with experience and knowledge will be greatly appreciated.
Jeff
'64 swb stepside (gone)
'57 1 ton
'53 phone truck
'59 swb
'46 1 1/2 ton
'68 swb gmc
jfnar #920066 02/15/2013 2:28 PM
Riding in the Passing Lane
I run the T-5 behind 350 v-8 & dont have any problem. As long as you don't go doing burnouts or speed shift, it should stand up OK. You dont want to lug it in O-drive. Its better to down shift to direct drive.
1972 Chevy c10 Cheyenne Super
jfnar #920342 02/16/2013 5:37 PM
1 Offline
I have one behind a 292 and an open drive line with 3:08 gears and it is a marriage made in paradise. Good acceleration, good mid and high speed response and also decent fuel mileage.
Normbc9
jfnar #920355 02/16/2013 6:58 PM
1-12:
What model/year of truck do you have. What rear end did you swap in? I've often thought of the same combo for my 58 Suburban.
Larry
jfnar #920409 02/17/2013 2:22 AM
Larry
Read His Post.
59 swb....{aka short wheelbase}
regards,
steve sr.
jfnar #920977 02/18/2013 11:15 PM
I HAVE A 49 BURB WITH THAT COMBO AND A 3.28 GEAR RATIO REAR END ITS A NICE COMBO
jfnar #921068 02/19/2013 11:47 AM
What kind of gas milage do you guys get? My rear ratio is 3.73. I'd like to get close to 20 but I don't know if that's achievable.
'57 1 ton
'53 phone truck
'59 swb
'46 1 1/2 ton
'68 swb gmc
jfnar #923581 02/28/2013 8:00 AM
Steve;
Dooh!
Cut Master:
How did you get the 3.28 ratio? Was it a rearend swap of a gear change? How hard was it to do???
Larry
