7 members (MickeyP, RoadsScholar, Gdads51, 1955 1 Series, thekid1950, tclederman, klhansen), 117 guests, and 1 robot.
Topics128,081
Posts1,056,068
Members48,433
#917883 02/06/2013 9:10 PM
I just bought a 61 Chevy apache 20 with a 235. well it ran but found that it was putting water in the oil. So i pulled the engine took the head off and found that number one piston wrist pin had worked it self out of its original position and made a nice deep groove in the cylinder wall, all other cylinders are good and the head is cracked between the valves. So what am asking is the 235 a good engine and if so im in nebraska and cant find parts or another engine. Need help.
chevyrambo #917888 02/06/2013 9:22 PM
Originally Posted by chevyrambo
. . . So what am asking is the 235 a good engine and if so im in nebraska and cant find parts or another engine. Need help.
Welcome to Stovebolt.com
The 235 is a good engine.
Check the Swap Meet - Parts For Sale. Or, place a Want Ad in the Swap Meet.
chevyrambo #917900 02/06/2013 10:22 PM
Rambo,
There's a 235 on Craig's list for $350 in air park in Lincoln. Check the junkyards they are all over.
Tom
Tom
1965 Chevy C10, 230 straight six, 2WD, 4-speed manual
chevyrambo #918391 02/08/2013 6:15 PM
There should be plenty of 235cid engines about, May I suggest if you are going to replace a engine look for the larger 261cid.
Howie
1 1955 Chev one ton. 261 engine
3 1962 Chev c-10 261 engine
4 1966 Plymouth VIP 5.7 GenIII Hemi
5 1966 Imperial Crown Coupe 440 engine
chevyrambo #918894 02/10/2013 6:05 PM
Crusing in the Passing Lane
If the block is good other than the wrist pin damage you can get it sleeved. The 235 was used in a lot of different Chevys for years, there has to be engine in your neck of the woods.
Currently cruising
in the Passing Lane
Rest in Peace
chevyrambo #919577 02/13/2013 11:45 AM
I think the supply is drying up. Lots probably ended up as scrap iron.
chevyrambo #919950 02/14/2013 11:16 PM
Been looking on craigslist and havent found any, And yea when iron price was up a while back everyone took almost everything to scrap. I remember driving by farms and jusnk yards an seeing alot of old trucks and now not so much. But will keep looking.
chevyrambo #919954 02/14/2013 11:49 PM
Tom
chevyrambo #919973 02/15/2013 6:39 AM
I have a 61 235 W/side mounts turns free came from a running vehicle it does have the 848 small chamber head also. I am in Northeast Ks
chevyrambo #935443 04/13/2013 4:30 PM
Well I just found another engine I think its a 261 its out of a 1962 c60 straight truck Here are the numbers from behind the distributer (F0509LB) Can anyone help.
