8 members (Hotrod Lincoln, sudsyz, Chip O, Gdads51, 1955 1 Series, stlcardinalsguy, tclederman, 1 invisible),
67
0
Mod | | | Forums66 Topics128,210 Posts1,057,456 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2010 Posts: 65 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2010 Posts: 65 | HI Have been working on the front leaf springs, pulled them off cleaned them up, replaced shackles, as well as replacing the main leaf on both sides.
There was a shim under the spring on the right hand (Drivers side) but not on the left side.
Not sure if I should put the shim back in - any advice Denis | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Originally they are on both sides. They are called caster shims. They help high speed stability.
See the USA in your vintage Chevrolet! My Blog | | |
