0 members (), 138 guests, and 3 robots.
Topics128,196
Posts1,057,391
Members48,471
HI
Have been working on the front leaf springs, pulled them off cleaned them up, replaced shackles, as well as replacing the main leaf on both sides.
There was a shim under the spring on the right hand (Drivers side) but not on the left side.
Not sure if I should put the shim back in - any advice
Denis
Originally they are on both sides.
They are called caster shims.
They help high speed stability.
My Blog
