3 members (tclederman, Bill Hanlon, 1 invisible), 197 guests, and 3 robots.
Topics128,106
Posts1,056,213
Members48,436
Two unrelated questions. I am beginning to wire my 57, and have become quite familiar with the Factory Assembly manual and wiring diagrams, but nowhere can I find any mention or drawing of a fuse block. I looked through several catalogs, and they all carry one, and their drawings all depict the same unit. When I stripped the truck 3 years ago, there were a few in-line fuses spliced in by POs, but no fuse block. I ordered one, but need to know where to put it. Intuition says to mount it just above the vent grille by my left foot, but is there a better place ???
Second question is about turn signals. I have the steering column from a 70 'burb in this truck. It came with the big curved plastic connector intact, but only the half connected to the column. Where can I buy the other half which feeds into the wiring harness ??
Junior Member
Junior Member
If you're adding an original fuse block and you have original firewall insulation, look for a little square perforated area in the vicinity you think the fuse block should go. This piece of insulation gets popped out to allow the bracket on the fuse block to be screwed directly to the firewall.
59redtruck's right on w/ the fuse panel, Russell, but note that's on the inside of the firewall, not on the kick-side, and the reason you didn't see any reference to the fuse panel, or have one on your truck, is they were only put on trucks that had enuff factory installed options to make'em useful - most TF trucks came w/o
for the turn connector, might be able to find it from one of the wiring supply places, or even yer local GM dealer, but best to hit the wreckin yards and find the piece ya need and remove the wires and put it on your wires
